![]() | Home > Faults & Fixes > 2010 Range Rover Sport 3.0 TDV6 - Gearbox fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
Seized gear linkage
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Emergency fix if you cant get in a garage is to get underneath, drop the gearbox shield clean the linkage with penetrating oil or similar while working the lever then spray some silicone grease on it.
