Home > General > technical bulletins related to car
mgrover
is there somewhere I can stick my vin in and find out all the service bulletins related to it? ive already found two that apply:
1. software update that fixes the fuel trim errors
2. supercharged coolant pump
A possible third and fourth to do with clogged injector from what I can tell and a recommendation to use bg44k and my rear brakes have started to squeal.
so is there anywhere i can try and address all the technical bulletins
cheers
Post #599237 Sun May 24 2020 5:18pm
pay for a topix subscription and down load them
you used to be able to pay for a days access.
I don't have the ones for petrol models it seams
Post #599241 Sun May 24 2020 5:40pm
rear brakes
Situation: A customer may report a concern of a squeal or clicking noise, or of excessive brake dust
coming from one or both of the rear brake hubs.
Cause: The electronic parking brake, brake shoe retaining clip has become dislodged or has broken,
leading to the above complaint.
Action: Should a customer express concern regarding the above, refer to the Service Procedure
detailed in this bulletin.
PARTS:
2off SFS500012 Parking brake service kit
Renew both rear parking brake shoes using
the above parts kit, which includes the
modified design shoes, retaining clip and
return springs (illustration shows both lefthand
and right-hand shoe arrangements and
indicates the retaining clip locating slot).
Post #599242 Sun May 24 2020 5:45pm
Disco_Mikey
As above, pay for a days access to Topix for you model and MY, and download to your hearts content Thumbs Up
Post #599246 Sun May 24 2020 7:20pm
mgrover
ahh all on topix eh? ill do that, thanks Very Happy
Post #599248 Sun May 24 2020 7:44pm
mgrover
on the above bulletin. is it worth just doing the discs while am there? id do the pads but i did them when i got the car and have only done like 4k
Post #599250 Sun May 24 2020 8:02pm
