![]() | Home > Faults & Fixes > New owner with 'restricted engine performance' query |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4482 ![]() ![]() ![]() |
Your gut feeling should be to have the fault codes read, and a fault diagnosis carried out before replacing parts unnecessarily |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
I had this and it was the throttle sensor Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Throttle body,I had same problem the flap in the body was stuck,LR assist came out pulled front pipe off freed the flap & all was good.luckily mine is still under warranty so when it went in for service they fitted a new throttle body. Andy.
Where that little yellow mark is put a screwdriver under the metal clip,lift up & pull the front pipe off & flap is there,you can spray in with throttle body cleaner to help it.
phey708 Member Since: 14 May 2020 Location: Lancashire Posts: 3 ![]() ![]() ![]() |
Thank you everyone. Unfortunately it didn't store any codes so I don't think replacing the MAF sensor would really work at this stage. I did notice that it was a new-ish part (looked to be in good condition) so it may have already been replaced recently anyway.
