![]() | Home > Faults & Fixes > Range Rover Sport TDV8 Running Troubles |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9119 ![]() ![]() ![]() |
Sadly, you're going to need to get the error codes read. Otherwise you're just going to play "pin the tail on the donkey" with this. There could be a number of factors causing the problem and you don't want to be changing stuff for the sake of it. 2012 SDV6 - it's missing a couple of cylinders
tricey27 Member Since: 01 May 2020 Location: Yorkshire Posts: 10 ![]() ![]() ![]() |
Thanks for reply.
Download the workshop manual: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf and search that with your favourite pdf viewer.
As a starter, I'd guess a new fuel filter is required. Buy a real one, not a cheap aftermarket part as these have been known to be an issue. Hopefully, that'll sort it. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Great.
UPDATE!
