Home > Maintenance & Modifications > Oil leak
mgrover
Oil leak
I have an oil leak. Its a bit odd how given both heads were rebuilt about 2000 miles ago. so i was looking around and supposedly the valve cover gasket is a common issue and if the rebuilder didn't use a new gasket its reasonable that this occurs. But I can't seem to find any instructions or even parts.
Its the 4.2 SC 2006 engine. Or is it gasketless? Because the next place is the timing chain cover.
Post #597790 Wed Apr 15 2020 10:50pm
According to this there are gaskets fitted (£30.00 each for genuine L/R one's), in addition to having to put a couple of beads of silicone sealant in the areas marked with arrows.
https://www.island-4x4.co.uk/advanced_sear...28&y=9
https://www.island-4x4.co.uk/advanced_sear...26&y=8
Post #597791 Thu Apr 16 2020 12:08am
mgrover
That looks perfect, cheers Col. Ama get some tracer fluid next week and if its the gaskets hopefully its a nice easy change. Although I doubt it
Post #597794 Thu Apr 16 2020 8:20am
mgrover
Bit of an update to this, did my right side, the gaskets don't fit, so I was like well my fault for not getting oem, so I went and bought oem. Same issue their too small. Lr said they'd been revised. I ended up cutting my old gasket and patching this one with some gasket sealer. Not pretty but does the job.
Did a smoke test and it's air tight atleast
Post #602116 Fri Jul 24 2020 2:02pm
