Home > General > Steering wheel |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
I did this mod quite a few years ago, It is possible to retro fit a heated steering wheel but not as straight forward as just bolting the wheel on, don't ever recall seeing a pre-facelift RRS1 with factory fitted one, no heated wheel listed in the parts list either for the pre-facelift. Strange though because my old 09 plate pre-facelift actualy had the wiring there up to the clock spring although not the correct clock spring fitted. Quite a lot of posts on this subject if you do a search.
Wed Apr 15 2020 10:32pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Ok thanks. I'll do some research.
Fri Apr 17 2020 6:11am |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
I know of one being fitted to an 05 plate disco 3 so I would imagine so. You need a clock spring, heated wheel and it will also need to be enabled by an IID tool. I ordered one on my last D4, they forgot to fit it so the dealer retro fitted but had to get Disco mikey to come and Enable it!
Fri Apr 17 2020 6:41am |
If it's being retro fitted to a pre-facelift sport you do not need to enable it as they were never a option on the vehicle in the first place, or at least I didn't have to on mine and that was a 09 plate. You will also need the new circuit boards from Blackbox solution's.
Fri Apr 17 2020 6:54am |
Right. This is getting urgent. I will pay someone to install a working heated steering wheel to our 05 RRSS if I have to otherwise it’s gonna cost us 10-15k for one. That includes a newer car by the way.
Mon Apr 27 2020 8:13pm |
I don't know what your mechanical/electrical capabilities are but it is a relatively simple diy job, when I did mine way back I used all new parts from L/R and Blackbox Solutions, with a brand new steering wheel and total parts cost around £1000.00 But I would think apart from the circuit boards you could get all the bit's off ebay a lot cheaper. You need a complete heated steering wheel with switch packs from Sport or D4, a heated wheel clock spring, be sure you get the right one as a lot advertised are not the heated version, I did previously post pictures of the correct one showing the differences and part number, a wiring connector and fly lead available from the Site Shop, circuit boards from Blackbox Solutions, and either the tool to remove the airbag or bent coat hanger will do it. You will also need to wire in a supply to the connector fly lead as a 2005 car will not have it already.
Mon Apr 27 2020 11:04pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Might be cheaper to get a new wife |
Tue Apr 28 2020 1:35pm |
Thought about that but it definitely won't be cheaper.. |
Tue Apr 28 2020 9:14pm |
Buy a 2010-2012 heated wheel from a disco or sport buy the boards from Blackbox solutions remove wheel check clock spring has the heated feed(which i doubt) fit boards to new wheel refit new wheel and bob's your uncle there goes about £350-500 but well worth it did it to my Disco 3 and moved it to my Sport supercharged the early Disco's did not have it as an option i don't think |
Wed Apr 29 2020 5:18pm |
You may be lucky to find a wheel with the boards i sold mine last year for £375 complete and it sold very quickly |
Wed Apr 29 2020 5:20pm |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 |
I bought a heated steering wheel from geoff ^^^
Wed Apr 29 2020 7:14pm |
Yeah you would think after all this time Blackbox may have reduced the price of it all as it’s a few years old now can’t be many more wheels left to mod as said though by Devon it is one of the best mods to do |
Wed Apr 29 2020 7:46pm |
