![]() | Home > General > Gap iid tool parking aid |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Why not just replace the sensor and have a fully working system? Or see if the system has a dedicated fuse and pull that. But fixing it rather than fudging it would seem the right option. 2012 SDV6 - it's missing a couple of cylinders
quadrant Member Since: 28 Oct 2019 Location: Sheffield Posts: 6 ![]() ![]() |
Thank you for the reply, I will be replacing the faulty sensor as soon as possible to get the system functioning correctly but in the mean time I thought I would be able to completely disable them using my iidtool.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
It sounds like you selected rear only fitted.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
There's a fuse somewhere (on left I think) and removing that disables front/rear sensors and annoying beeps very well |
I think the fuse removal method might be the way to go in the short term lol...
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Could try Fuse 36 5amp behind passengers side glove box.
Cheers Col, its got to be the fuse removal for the moment - Patrick @ GAP has confirmed that the beep will still be present if there are any faulty sensors even if you disable the parking aid with the iid tool , it is a self test kind of thing that still reports a visible and audible warning if there are any faults on the system.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I believe that GAP are very helpful if you phone them - assuming they are currently available of course... Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
