![]() | Home > Technical > No ignition on RRS 2010 5.0sc |
It sounds like the KVM has either corrupted or prevented a theft. Are there any signs of entry attempts? 2019 5.0 SC SVA (Current)
I think there’s a manual way to start the car, have you checked the handbook? 2019 5.0 SC SVA (Current)
Kuikka Member Since: 12 Apr 2020 Location: Finland Posts: 5 ![]() ![]() ![]() |
I cannot see any obvious sign of attempted theft.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5110 ![]() ![]() ![]() |
tried charging the battery ? |
Have you tried these? This is from my 2012 manual, the petrol procedure is interesting.
Yes, and swapped to a new one and tried with power source.
@Brit Plumber
Ok I’d go back to basics and check the fuses and relays in the main fuse box if you haven’t already. The fact that the BCM is reporting sounds like it’s not but it’s worth a check. 2019 5.0 SC SVA (Current)
DTCs
Check Link 17E and 15E in the engine junction box. 2019 5.0 SC SVA (Current)
Also 18E in engine box and fuse 40P in the CJB (for MS Can). 2019 5.0 SC SVA (Current)
Was a bit busy at work so didn't have time to visit car until today.
Rooster99 Member Since: 14 Oct 2020 Location: devon Posts: 2 ![]() ![]() |
Did you get to the bottom of this fault? I have one that the ignition wont turn on after the vehicle is warm |
