![]() | Home > Maintenance & Modifications > Replacement battery for 2012 L320 SC |
drexal Member Since: 18 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hi guys,
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
I changed mine in September having asked here on the forum for advice. Here is the thread
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
Personal choice but from previous experience wouldn't fit a Yuasa if they paid me, unless they have improved in reliability drastically. Fitted a Varta G14 (019) AGM nearly 4 years ago and has been faultless, but as I say personal choice.
Thanks once again for all your guys help. Ahhh dam Col I ordered a yuasa yesterday before I read your post.
Absolutely no need to fit a stop/start agm battery, it was just purely a personal choice which I thought I would try, didn't really consider the price.
As Col said, YUASA can be a bit hit or miss. My first YUASA (I went for a 020 for a little extra power) internally blew a cell in the first months and blew my camera module in doing so. The battery was replaced under guarantee and I’ve since heard of at least another 3 RRS owners having very similar issues with the 019 and 020 batts. So if you have further elec problems, I’d re-look at the battery to be sure. 2019 5.0 SC SVA (Current)
Thanks for info Col & Brit Plumber ahhh dam. I'm wondering if i still have time to cancel it. Because i desperately don't it break anything electrical.
I don't think for one minute every Yuasa battery is going to fail I'm only speaking from my experience with them. I fitted the 019 because it is a straight swap and don't have to squeeze it in, it is a larger capacity than the original factory fit battery for the petrol variant anyway and as said have never had a flat battery or starting issue. Again personally I would only fit Varta as have never had a issue with them although not the cheapest battery, also although L/R branded they were also the o.e. battery on the s/c.
Thanks Col,
