Home > Technical > Update....My RRS is a runner.
Devon Z
Went out to do the weekly shop today and she didn’t start first time, when she did start she seemed okay but a little distance down the road she went into limp mode then stopped and wouldn’t restart. Popped my code reader which I carry in the boot on and code PO62D “fuel injector driver circuit performance bank 1“ comes up.
She’s currently being recovered but the breakdown trucks hydraulics blew while we were being pulled up the ramp! 2 hours to get the winch to release so they could get it back off! They’ve gone to get another truck hopefully she’ll be back home later?
I’m thinking this may be a garage job?
Steve Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #597440 Mon Apr 06 2020 5:57pm
Check injector wiring for chaffing.
Probably needs a new engine ecu ,
But it contains the imboliser 😞
Post #597443 Mon Apr 06 2020 7:02pm
Devon Z
Cheers Andy, are the ecu’s prone to failure then? more so than injectors? I’ll check the simple things first, I’ve checked the plugs and wiring behind the battery and a quick look at the injector loomed on top of the engine.
Steve Steve
Post #597444 Mon Apr 06 2020 7:17pm
No ecu aren’t a common problem
1 injector failing shouldn’t stop it
I guess u should do the basics and check there is high pressure fuel at the pipe joints, by loosening one slightly.
You can get imboliser ecu kits off eBay if you conclude it needs it
Post #597449 Mon Apr 06 2020 9:06pm
Devon Z
Info i gleaned from the Internet is injector firing info to the ecu is shared between two injectors so if one goes down it effects two, I’m at work on nights at the moment so lots of time to surf, info from the Disco 3 site points to injectors or wiring loom, I’ve got a resistance figure to check the injectors so at least I have a starting point.
Steve Steve
Post #597455 Mon Apr 06 2020 11:58pm
Devon Z
Update
Finally got some time off to investigate and it appears that water may have got into the engine ecu, I found a large round grommet in the bulkhead above the ecu behind the loom out.
And water damage to the ecu pins.
So I’m looking into my options locally
1 - Exchange or rebuilt ecu, upto £160 + vat and parts
2 - Buy a second hand ecu and get it cloned, around £80 cloning unknown at this point
Waiting to hear back from a couple of specialists as they may not be working at the moment.
Steve Steve
Post #597806 Thu Apr 16 2020 5:47pm
Brit Plumber
Have you tried cleaning the contacts or are they rotted out? If rotted, do you think the ECU is toast or could a new connector work? If you open the casing and look at the connector, mouser Uk or similar probably carry a replacement circuit board connector. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #597807 Thu Apr 16 2020 7:28pm
Yeah clean contacts and see how bad inside.
[quote="Andy K]
You can get imboliser ecu kits off eBay if you conclude it needs it[/quote]
Post #597809 Thu Apr 16 2020 8:18pm
Devon Z
No it was very light corrosion that cleaned off, I haven’t had the lid off as it seems to involve bending the edge of the lid then it looks stuck on with black mastic and if I was going to get an exchange unit it wouldn’t look good.
It’s only effected the first plug which runs the left bank which was the error code I had when she broke down.
After cleaning it up and refitting I had 11 error codes on the engine alone! But after 2 or 3 code resets we’re down to 6
PO62D injector driver bank 1 - original fault code
Plus these now
PO62E injector driver bank 2
POA09 DC/DC converter
PO670 glow plug module current low
P1335 EGR position sensor minimum stop performance
P2138 throttle pedal position switch
Going to pull it off again tomorrow and may take the lid off and have look?
Steve Steve
Post #597811 Thu Apr 16 2020 8:38pm
I think the DC DC code means it’s fxxked Censored
Yeah probably wise to leave the lid on unless your an electronics expert
Post #597812 Thu Apr 16 2020 8:50pm
Devon Z
Thanks Andy, I think you may be right that’s why the other banks now got a fault plus the other errors.
I’m thinking a cloned s/hand units going to be the most cost effective option but we’ll see what it costs?
Steve Steve
Post #597813 Thu Apr 16 2020 9:46pm
Devon Z
Been in touch with three local specialist, two are getting back to me if they can do it and one has given me a price for an exchange cloned unit of £425, bit much but on a 14 day return basis if it doesn’t work(£96 restock fee)
Got plenty of time to sort it out anyway and have another car to use if necessary.
Steve Steve
Post #597871 Sat Apr 18 2020 3:55pm
Devon Z
Sounds like my ECU is toast and they may not be able to pull codes from to clone, They’re going ring me tomorrow, if this is the case what are my options?. One that’s been mentioned is to replace the ECU set with a coded set from a donor vehicle? what parts do I need for this as there seems to be various available?
Is the coding required just for the immobiliser? can I bypass that?
Any help appreciated
Steve Steve
Post #598254 Tue Apr 28 2020 1:20pm
Devon Z
Update........My ecu is now at a new specialist and repair work is ongoing, damage was so extensive that repair work is being carried out in an attempt to retrieve Software and codes Sad I’m remaining positive.
Steve Steve
Post #599276 Mon May 25 2020 5:19pm
knwatkins
Sounds expensive Shocked Kev
Post #599343 Wed May 27 2020 10:56pm
