![]() | Home > General > P400e Dead to the World |
cormacr Member Since: 10 Jan 2017 Location: Wicklow Posts: 33 ![]() ![]() ![]() |
I have a 9 month old P400e that will not power up when I press the start/stop button. I drove it a week ago and it was perfect, went out yesterday morning and the door locks open with the keyless entry and the interior/exterior lights come as normal. The dash and center displays are completely dark. I thought the battery might be low so I measured the voltage - it was showing at 12.5V so i put in on charge overnight and it's now at 12.6V (=100%) and still nothing. I tried the second key and it made no difference. The boot will open and close on the button or key fob so there's enough power for that, there's no Low Battery warning or any other warning symbols. Tried jumping cabling to another battery.
Are the LR assist not working.?,I know the likes of AA & RAC ect are working. Andy.
Thanks guys, I'll check the battery voltage again after it's been off charge for a while. Andy, I'll give Land Rover Assist a try and see if there is still support available? Current: RRS P400e PHEV HSE Dynamic MY19.5 Santorini
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
This shows how a battery is charged or not
Thanks Lindad, I am getting 12.4V and the boot lid won’t open under power, it will close once I open it manually. So I’m guessing that I have a dud battery. I’ll contact Land Rover Assist tomorrow. I’ll also try jumping it off my wife’s Discovery 5. Thanks again. Current: RRS P400e PHEV HSE Dynamic MY19.5 Santorini
Something more going than the battery. I connected it to the Disco 5 with jump leads and the car will still not power up!
You may have a parasitic drain which is bringing your battery down. More than likely with only a 9 month old car. I had that on mine.
Yes, checked connections - they are ok. The headlights switch on from the key fob and look normal for brightness. I am wondering if a fuse is blown, will do some more research tomorrow! Thanks again for the suggestions.. Current: RRS P400e PHEV HSE Dynamic MY19.5 Santorini
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
Possible dodgy/loose earth connection somewhere? 2012 SDV6 - it's missing a couple of cylinders
Success!
Great news. |
Good job you had the Mini PHEV to fall back on....... |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Uk dealers have been offering a non contact service for those in key worker positions (had an email a couple of days ago). Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Yes Tim, the Mini is brilliant - hasn’t let me down! I drive it 2/3 of the time to keep the mileage down on the RRS.
