![]() | Home > General (L494) > Electronic Gearbox Fault |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210 ![]() ![]() ![]() |
Do you have any means of reading the error codes from the vehicle? --
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
What did LRA say? Joined the X5 45e club
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
There is a pivot where the cable goes into the gearbox, on the right hand side from memory. Although its behind an undershield, it is exposed to muck and water and stiffens up preventing gear selection. If it is this, jack it up, take off the shield, spray with a penetrating oil, or something like WD40, and work it till it frees off. Then spray with a silicone spray. This will get you going till you can replace it, fairly cheap part. |
Here you go;
is it the same for the 8 speed? Joined the X5 45e club
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
Hi its an electronic gearbox so not a pivot or anything sticking landrover assist says its something to do with communication to tell it to go in gear it happened a few months back and the AA came out to recover it and took it to landrover dealer who said when I collected it that they couldn't find anything wrong as it was fine when they went to diagnose it ?
I didn't realise it was an 8 speed |
KM RRS Member Since: 21 Feb 2020 Location: Midlands Posts: 9 ![]() ![]() |
Hi Dazzerboy
Hi it never got resolved but all as been ok since landrover just say they cant find any fault codes |
Hi again. I asked AA and they sent me the call out report, which includes the fault codes. It may not be too late to get yours.
