![]() | Home > Technical > Updating ECU via IID |
The consensus is, don't update unless you are experiencing a problem. It's not like a Windows update on your PC. Kev
Agreed, if everything’s working Then don’t update (unless it gives you more functionality). 2019 5.0 SC SVA (Current)
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 ![]() ![]() |
and id agree both both of those if its not like computer firmware updates etc.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
While I understand the "if it ain't broke don't fix it" thoughts, surely there must be an improvement made with a newer firmware version, as in the manufacturer made a fix or improvement even if it did not appear to affect us?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
JLR are having huge problems with the ICTP, with newer firmware actually making the system worse |
