Home > General > Coolant issue please help!!!!
Harryrrs
England 2007 Range Rover Sport TDV6 Autobiography Java Black
Major coolant issue ,
Previous owner used some type of stop peak fluid to stop a leak in coolant system causing a everything to become blocked , the coolant level squashes down causing the warning on the dash. Howether once cooled down the coolant level comes back up.
When reving the car the coolant level drops right down and returns when reving released .There is a constant flow of air bubbles at top of coolant tank ,
Block tested several times and clear everytime , No oil and coolant contamination , no smoke and engine runs spot on .
A Lr specialists has tried all sorts but no luck
New radiator
New thermostat
New coolant bottle
New coolant cap
New passenger side egr cooler
New oil cooler [oil filter housing]
New water pump ,
System has been flushed through several times and parts been cleaned out and coolant seems to be flowing through everything
Some one help me ....... Censored Censored
Post #595254 Thu Feb 20 2020 7:26pm
