Home > General > T&S Norman to the rescue
Stevepd
I’ve been monitoring a suspect injector giving me lumpy idle on start and occasionally on warm idle. IID tool says Cyl 1 was at max flow and a live reading showed it at around 1390. I’ve seen that T&S have come recommended on the disco3 site so for some reason I thought I’d break away from the indie I’ve been using and give them a try. I spoke with Steve who explained who/what and why so it was booked in. I was braced for 6 injectors just in case. As it happens only one was needed and the figures are now all similar and it’s smooth as a smooth thing hot or cold.
I liked Steve’s set up and the true British barn style specialist. Outside was a fleet of L405, L322s and it just feels right. I’ve found me new indie for the time I keep the car.
He’s given me a list of stuff that needs addressing and March sees it’s annual service + cambelt/oil pump so an expensive month ahead but we’ve decided it’s a keeper anyway. I’ve only got 75k on the car and Steve says it’s all age related wear as the car is 14 years old now. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #594533 Sat Feb 08 2020 9:29am
knwatkins
Steve Norman is a top bloke Thumbs Up
When my 3.0 TDV6 spun a bearing, he was kind enough to spend a considerable amount of time on the phone with me giving me some great advice. You won't go wrong with him.
Glad you got your injector sorted Steve. Kev
Post #594536 Sat Feb 08 2020 9:59am
knwatkins
Out of interest, what else did he pick up on? Kev
Post #594537 Sat Feb 08 2020 10:00am
This is the sort of service that the big main dealers in their luxury glass boxes don't understand.
Great to hear positive stories about indies. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #594543 Sat Feb 08 2020 11:06am
DrRob
We all need a Steve Norman in each county Bow down Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #594551 Sat Feb 08 2020 4:41pm
Boxers
It is great when these guys are found, sounds very similar set up to the one I was recommended to in Peterborough gives you confidence when you see a 1 year old RRS entrusted to them rather than a main dealership, he even had one off its chassis having an engine rebuild & was proud to show me his work area.
Post #594555 Sat Feb 08 2020 5:20pm
Stevepd
Bushes bushes oh and bushes and just for variety a noisy bearing and a weak shock absorber + corroded brake hose. I’m not going to talk money as I don’t think it’s right but we’re going to get it done Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #594557 Sat Feb 08 2020 5:58pm
DrRob
With a Bodsy Megaflush and Steve Norman servicing, your Sport is well pampered Steve Thumbs Up Bow down
How’s the gearbox after 1 year post flush ? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #594571 Sat Feb 08 2020 11:37pm
Stevepd
Hi Rob, just fine and dandy. Still silky smooth even though I’ve done 20k ish since it was done Censored . How’s your FF been over the year?. I remember you having an oil cooler leak if memory serves. And how’s the classic? It’s the most expensive seat I’ve ever sat on to have tea and biscuits Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #594580 Sun Feb 09 2020 10:12am
DrRob
Gearbox all good. Leaks sorted = oil cooler, oil pump plug and a turbo. The hatrick!
The seat is still comfy Rolling with laughter * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #594697 Tue Feb 11 2020 1:07pm
