![]() | Home > Maintenance & Modifications > Electronic parking brake in reverse?? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Could it not just be the effects of gravity, vehicle weight going forward downhill, you wanting it to go backwards so have to give it slightly more throttle which gives the impression of the brake initially sticking? Mine does a similar thing when I reverse over a slightly raised lip to reverse in my garage.
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
There is a definite something that is stopping movement as you can feel a release take place. There is no replacement for displacement - W O Bentley
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Is that not hill start assist? I can't say I've likely had cause to try it when reversing, but it does that, say at a junction on a hill when going forward, the brakes are applied for some time to hold the RRS until you drive. 13MY Range Rover Sport Autobiography SDV6 - mine
Do you not have to switch the hdc on for that to activate though?
I've never activated it when at a junction on a hill, it just does it automatically. I've never actually used HDC other than a play/test, but when I could do with it I can never remember how to speed up/down so I feel safer not using it |
Show how much notice I take didn't even realise the RRS1 had hill start assist though it was all part of the HDC, just found this in the sales brochure. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
I think Gradient Control was added at the facelift in 2010. 2012 SDV6 - it's missing a couple of cylinders
