![]() | Home > Technical > 5.0 Supercharged Air intake |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Pretty sure it's both sides, but can check later to make totally sure.
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
Thanks Col, the drawings show both sides but truthfully i was hoping for just the drivers side |
Guess you were hoping there might be a N/S snorkel available. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
Changing engines Chris? |
![]() ![]() I was considering a change of engine and swapping everything over as i do fancy a charger Wayne! ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐ |
I fancy a 5.0 too but I do way too many miles - it's bad enough at mid 20s average. AT mid teens (or lower) the old credit card wouldn't know which way it was going! |
Had my L320 S/C about 6 years never bothered much about fuel but reckon the average is around 13/14 mpg. in the real world, any more and it's being driven like Miss Daisy. |
Thats the beauty of flying to work ![]() ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐ |
Thereโs a takeoff from both vents, I fitted aftermarket SUPERCHARGED worded vents to my car and it came with the one side blanked off. Luckily the aftermarket item were obviously made in the same Chinese factory as the original and I could swap the required bits over. 2019 5.0 SC SVA (Current)
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Had mine exactly a year now and in first 7000 miles (mainly short journeys 4-10 miles) have averaged 17 MPG. It's not often driven hard but then again not that steadily either. Worst I've seen for instantaneous MPG reading under hard acceleration was 2 MPG! ![]() MY2013 5.0 Supercharged HSE L320 |
Thanks for the input, i was hoping that it was only fed from one side, so looks like i am going to have to have a think in which direction i wish to go ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐ |
A friend has recently bought a 4 year old, 60k mile L405 FFRR 4.4 SDV8 Autobiography. Had a look last night. Fabulous bit of kit with a good lot of toys/options including the Meridian sound system. A heck of a lot of vehicle for ยฃ38k.
