Home > Technical > Grrr! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
I have posted regarding my sons 2007 tdv6 many times with problems ranging from shattered engine to faulty inter-cooler to removal of ace system!
Sun Jan 26 2020 8:34pm |
It is going to be sold but need to get yellow lights off first to get through mot! I was hoping it would be something like getting epg reset? |
Tue Jan 28 2020 1:53pm |
If the epg works on and off i would have thought after a few cycles of the ignition and running or get codes read and cleared which may work or tell you whats wrong |
Tue Jan 28 2020 2:12pm |
Ok, will do.
Tue Jan 28 2020 6:52pm |
No but you can try a hard reset which means disconnecting battery and placing the positive and negative battery cables together (well away of course from the battery) and hold them together for a while it discharges and resets the system to a point so may work for you if you have no faults or search for hard reset on here to find out more |
Tue Jan 28 2020 7:03pm |
Ok, so i disconnected the battery and removed it, then held battery leads together for about 30 seconds and reconnected battery. Started up and moved off. All 3 yellows came on again along with HDC fault message, park brake fault and suspension lowered message. When stopped and restarted, all lights go out and suspension raises and lowers ok but when driven, all return. Park brake works ok. Just to confirm, the cars ACE equipment has been removed and reprogrammed to suit standard set up. Could it just need EPB resetting after driving backwards and forwards to unstick it? |
Sat Feb 01 2020 3:26pm |
