Home > Maintenance & Modifications > 2007 TDV8 RRS Turbo/actuator problems
Poco
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Hi All,
New to RRS's and to this forum so please be gentle.
Hoping you guys can help me out a bit.
Bought my first ever RRS about 2 months ago, all was good running sweet etc, then started to get EML on, looked up codes and got P140A, something EGR related I believe. It was at this point i was going to blank them off and have a remap, but, then i started to get what can only be described as a budgie under the bonnet at low revs, ( 900 - 1400 ) annoyingly running around town type of revs. high revs and it goes away. Big Cry
After a bit of digging I think that the N/S side (lh) turbo actuator is failing. I made a hook type tool and operated it manually from underneath and can replicate the noise.
My question is..... can the turbo / actuator be changed without taking the body off? I'm quite handy with a spanner but don't fancy the body off.
Any help or advice would be greatly received.
Also any good indy's in the East Midlands? Ashby De La Zouch Area
Thanks in advance
Post #593425 Fri Jan 17 2020 4:41pm
The actuator is probably ok
The inside of the turbo maybe sooted up.
Worth trying a bottle if Wynn’s vvt cleaner.
Yes people change the turbo body on.
Not nice but possible
Post #593432 Fri Jan 17 2020 5:36pm
Stand Easy
Poco my turbo is being replaced in Oldbury by a company who do it without removing the body. Best Turbos is the name. Can't vouch for them as I'm in Manchester and it's a warranty job.
Post #593438 Fri Jan 17 2020 7:16pm
Poco
Hi Andy k,
Thanks for your info, tried vvt cleaner, just in case but 99% sure it’s the actuator, both turbos running/spooling up ok, but the lh actuator is very lazy to respond, getting electrical signals ok but not moving very much. The link rod has free movement.
Post #593453 Fri Jan 17 2020 10:43pm
Poco
Yes seen their advert and contacted them.
Quoted £2000+vat to do both without removing the body.
If all else fails !!!
Post #593454 Fri Jan 17 2020 10:45pm
Arh. I see now your profile now says v8
Most jobs on v8 are body off sadly.
Inc turbo changing.
Post #593466 Sat Jan 18 2020 9:58am
Poco
That’s what I was afraid of.
My fear is, that if the body comes off that when it goes back I’ll end up with squeaks, rattles and electrical problems.
I’ll do a bit of research and probably attempt a turbo replacement myself, body on.
Post #593469 Sat Jan 18 2020 1:39pm
It's designed to be removed and there is just a process to follow removing and replacing it. It's not the big issue that some seem to think it is. 2012 SDV6 - it's missing a couple of cylinders
Post #593470 Sat Jan 18 2020 2:04pm
Poco
I thought as much, may be a little awkward but I’m prepared for that.
Reading the forums makes it sound very daunting, far more than it probably is.
Think I’ll try to research how to access the turbos a little easier and give it a go.
Post #593476 Sat Jan 18 2020 3:20pm
possible electrical problems (but you know to look at which connectors you touched)
no squeaks
Post #593479 Sat Jan 18 2020 5:43pm
Poco
Got it booked into a local indy next Friday for a firm diagnosis.
They seem to agree with me over the phone but would like a look to be able to confirm.
Got to be worth an hours labour.
Post #593484 Sat Jan 18 2020 6:19pm
Poco
Hi Guys, had it into a local Indy, first for a diagnosis then a week later to fit a leaking turbo hose.
However my problem is still there, squeaking / chirping sound at low revs 1200 - 2000 now.
Indy says would need another couple of hours for diagnosis, (thought I’d already done that) they’re saying possible turbo and quoting mega money (£1800 + parts + vat).
It’s seams to me that it’s left (ns) turbo actuator fault, as when I move the link rod manually, it makes the same noise.
Is the actuator lazy or is it the ring in the turbo?
Both turbos spool up ok, car great to drive, have p140a code for egr on same side, could this be my problem?
I’m reluctant to think so because I can make the car make the noise by moving the actuator arm manually!
Thinking of doing turbos myself with body on
Any thoughts / advice gratefully received.
Graham
Post #594353 Tue Feb 04 2020 10:30pm
Did the TDV8 not have a issue with warping the exhaust manifold and snapping some studs that caused something like that. Just have a vague re-collection of reading something to that effect.
Post #594354 Tue Feb 04 2020 10:41pm
Poco
I think so, but it doesn’t have that type of exhaust blow by type of sound, can’t see any tell tail signs of smoke around the manifold but must admit it’s a bit hard to see.
All my thinking is towards the turbo / actuator because I can make it make the noise on tickover with a little push on the push rod.
Starting to p!ss me off a bit now
Post #594357 Tue Feb 04 2020 11:30pm
ShooterNeil
I had turbos and brake lines done
 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #594479 Fri Feb 07 2020 12:38am
