Home > General > Replacing Rubber wing protectors front and rear.
roonie
After a while the rubber wing protectors part number CLB500051 (FRONT) and CLB500061 (REAR) Start to sag and make the car look untidy. Replacement parts cost approx. £70.
However if you by the exact same rubber strip for a Freelander LR001623 then it is £10 !!!!!! the strip is twice the length and you will need to cut to size with a hack saw. However one strip does front and rear of my 2011 ranger rover sport with a little left over. Just replaced both sides front and rear for £20 versus £70 for the exact same product albeit not cut to length.
just thought I would share the tip as very please with the result.
Post #593292 Tue Jan 14 2020 2:59pm
Bustanut
Top tip, thanks.
Post #593315 Wed Jan 15 2020 11:29am
Eaters
Nice one. Mine are a bit tired too. A job for the warmer days that are just around the corner. Wink Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #593327 Wed Jan 15 2020 2:49pm
