![]() | Home > General > Help Needed 2013 L320 powered tailgate switch |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
I did mine some time ago and certainly don't remember removing the outer trim with Range Rover on it, just the inner trim panel, you may find your new switch has one extra plug than the original as they did update the switch as it fits other models as well, not a problem as you can simply remove the extra wires and plug or just leave it tucked out of the way.
