![]() | Home > General > Tyre Pressure 21" |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
I have 275/45 tyres, my local tyre company said 40psi, but a tyre fitter says 36 would be better, and that's what I use now. 2010 3.6 TDV8 HSE (Gone)
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Thanks mate. Is that 36 front and rear? ===========================================
Yes 2010 3.6 TDV8 HSE (Gone)
Thanks mate. Will pop out later and change it. I’m currently on 33 front and rear ===========================================
Just a thought, I have a V8 which is heavier than your V6, so possibly 33 at the front would be OK, definately 36 at the rear.
I’m running 47 rears & 40 fronts,I was running 37 rears & 33 fronts but I’m on 295/40r22’s & it was a bit sloppy on cornering at high speeds & that’s the reason I’m now trying them with more air in them,I’m running them at the heavy load pressure that it recommends on the dash when you go into the tyre pressure recommendations.I hope this helps. Andy.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
For some strange reason I run 34 front and 37 rear in my RRS1 with 275/45 x 21" wheels/tyres, found it rode and handled just fine for me.
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
33 front and 36 rear works for me.. |
