Home > Maintenance & Modifications > 10A wire in centre console?
HughN
Wales
Can anyone suggest a wire somewhere in the centre console and that might have a bit of spare capacity - ignition-switched if possible?
The ones to the front/rear cigarette-lighter look a bit weedy to me.
Thanks,
Hugh
Post #592688 Fri Jan 03 2020 2:49pm
cigarette ones are the only ones I can think of
I think the fridge connector could be used for permeant 12v
Post #592692 Fri Jan 03 2020 3:22pm
HughN
Wales
Post #592697 Fri Jan 03 2020 5:27pm
Eaters
Just a query Andy but if the fridge connector was permanent live wouldn't this mean you could leave it on, thus flattening your battery? I'd have thought it was ignition switched. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #592741 Sat Jan 04 2020 9:54am
Eaters
Re: 10A wire in centre console?
Thanks,
Hugh
I haven't done it myself but how difficult would it be to run your own wire back to the glove box fuse box (under the carpet edge Question and then use a piggy back fuse on perhaps the horn fuse in there??? Robin
Gone:
MGZTT 190 2.5
Post #592742 Sat Jan 04 2020 9:57am
HughN
Wales
That could be a cunning plan, Eaters... Thumbs Up
Post #592744 Sat Jan 04 2020 9:59am
Eaters
What had you planned to supply off it? Robin
Gone:
MGZTT 190 2.5
Post #592745 Sat Jan 04 2020 10:01am
HughN
Wales
My tablet PC, which has a 12 V charger stating 6 A. The 'fridge connector is probably the way to go, though I will need to unwrap the loom to get enough wire to connect to - and, firstly, check it has power to it (before I find it needs a CCF change to activate it!). I have to assume the cigarette-lighter outlets aren't up to it and/or in use (they usually are).
Post #592762 Sat Jan 04 2020 5:32pm
It’s 15A per power outlet, so that is
Plenty. Connect to the wires under it.
Post #592776 Sat Jan 04 2020 8:04pm
Scrumpy
Not sure if it helps but the fridge stays powered on after ignition is switched off but only for a few minutes, then it turns off so I don't know if that means it has 12v permanent live feed or not.
As stated previously, otherwise it would flatten the battery. 2016 RRS SVR Estoril Blue
Post #592789 Sun Jan 05 2020 12:13am
