Home > Maintenance & Modifications > Fuel Filter leaking
hairbear50
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Bonatti Grey
Fuel Filter leaking
Had a strong smell of diesel so after raising and removing underbody protection primed the system and fuel is pouring from the top of the fuel filter (Crossland) is this a common problem with non genuine filters or could it be a bigger problem can@t get a genuine filter till saturday any ideas would be great cheers.
Post #592363 Thu Dec 26 2019 10:23am
Disco_Mikey
Crossland filters are worse than Censored
Fit an OEM or genuine filter, all will be resolved Thumbs Up
Post #592364 Thu Dec 26 2019 10:51am
hairbear50
Just as I thought this is somebody else I like to stick to oem or genuine may cost a bit more but you know you are fitting a filter not a tin wit some crap inside Cheers.
Post #592368 Thu Dec 26 2019 11:57am
rob cupples
I've tried several different types of fuel filter on my RRS 2007 TDV8. All except the genuine leaked around the top. I only use genuine now. Also, be careful not to over tighten the plastic drain at the bottom as they break easily.
Post #592371 Thu Dec 26 2019 4:00pm
N60613
Bosnia Herzegovina
MANN filters are known for quality.
https://www.onlinecarparts.co.uk/mann-filter-7280360.html RR 2012 4.4 TDV8
Post #592390 Fri Dec 27 2019 11:36am
hairbear50
Update genuine filter fitted and all good now thank you for the help
Post #592425 Sat Dec 28 2019 9:54am
