Home > Technical > Jacks and things
SomersetRRS
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Jacks and things
Hi all,
I'm new here and new to RRS so please go gentle Very Happy
I need to deal with a sticking rear caliper on my 2008 2.7. I have a 2 tonne jack and 2 tonne axle stands but concerned they're not going to be "man enough" even though I'm just dealing with 1 corner.
So... trolly jack or bottle jack and what height do I need it to extend to in order to get the thing off the ground? I'm also going to have to deal with a dodgy front wheel bearing the near future so will need to to cater for that too.
Any help appreciated.
Cheers.
Post #592086 Thu Dec 19 2019 5:47pm
PC76
the weight of the vehicle is 2.8t from memory and this is split evenly over the two axles, so technically your existing jack and axel stands would be ok to lift one corner.
However I would recommend purchasing a decent jack & 3t axel stands if you intend to do more work.
keep it in standard height mode for jacking purposes.
Post #592135 Fri Dec 20 2019 7:28pm
aaronjb
Apart from anything else, 3T jacks tend to have a higher lift than a 2T jack - and the car isn't exactly low to the ground Smile 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #592136 Fri Dec 20 2019 7:35pm
You can use 2 axel stands per corner on the drivers side if required.
The 2nd tends to take a fraction of the load, but useful none the less.
A discovery 2 red bottle jack is a very useful thing to have for maintenance and for emergency roadside use
Post #592137 Fri Dec 20 2019 8:12pm
gogsy1956
I got a set from sgs engineering,, they do deals with trolley jack and axle stands,, the jack I got was rated at 2,5 T with 3 ton axle stands and the jack has a 530mm lift. Depends how much you want to shell out. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #592139 Fri Dec 20 2019 8:58pm
Oldandconfused
Another one for SGS, I have the 3t 465mm lift. It's very heavy so not really suitable for keeping in the car but I have the utmost confidence in it (still use stands as well). I think they have a sale from time to time.
Here you go;
https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack
Post #592148 Sat Dec 21 2019 9:55am
HughN
Wales
A pad with a pin to engage in the chassis jacking-points would be good - and re-assuring if that is where you are lifting it. Don't forget the chocks under the floor of the boot. Wink
Post #592160 Sat Dec 21 2019 12:47pm
Oldandconfused
Quite a few on the Disco3 forum have trolley jack adaptors and they occasionally come up for sale.
When you decide on your jack, try googling or an ebay search for one.
Post #592161 Sat Dec 21 2019 1:52pm
riverblanche
Hi and welcome Thumbs Up
a lot depends what "You" are confident doing and trust you have good equipment
Think my trolley jack is 2 or 2.5T and use homemade stands Shocked (read line above Whistle )
can not remember ever jacking up via the chassis but would have it in offroad first if I did (its got to go up there anyway)
I jack up under the suspension arms with a wood packer to spread the load, the car nearly always wants to "adjust" it's self during jacking, no matter what combination of doors,boot/open/shut/hazards is suggested
Only time ours was jacked up was to change wheels/tyres
Remember having some work done on the front of our D3 at home (by a very well respected mobile) and he used a trolley jack under the front of the D3 and jacked up front end to work on both sides together (rack arms from memory)
Whats the worst that can happen Laughing
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #592163 Sat Dec 21 2019 2:09pm
knwatkins
I always remove the two air suspension fuses in the engine bay fusebox before jacking.
My jack is an Omega Magic Lift. It's a bit of a beast for DIY use and weighs a tonne (well, 30 odd kg), but it does the job of lifting the RRS no problem. It's similar to this: https://ebay.us/aLVnP5
I use 6 tonne stands on each corner which I have much more confidence in than 3 tonne ones I use for other vehicles. They only need extending a little bit and have a nice large footprint for stability. Kev
Post #592167 Sat Dec 21 2019 2:35pm
