![]() | Home > General > L405 L495 > L320 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Yes.
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Thanks mate.
Been running 21" SVR rims on mine for over 4 years and never had a issue.
Excellent. ===========================================
Might have my eye on a nice set of 22” off a 2015 Autobiography.
I’ve bought some 21’s coming early next week. However the question still stands regarding my speedo and mileage being out? Will this be the case? Anything I can do about it?
Your speedo will likely be more accurate because they read low by default. Monitor your speed on your phone via GPS and compare with your speedo to see how accurate it is.
Thanks mate. the alloys are coming with 275/45/21 ===========================================
Silly question.
Original L/R wheel nuts will be fine, don't bother changing anything in the CCF files it won't make any difference except screw up the cruise control speed compared to actual vehicle speed, or at least that's what mine did so left it at factory setting. As far as speedo is concerned it will it be just about spot on
Thanks mate ===========================================
