![]() | Home > General > RRS 2011 Autobiography SDV6 3.0 heater only blowing cold air |
C9LFS Member Since: 18 Apr 2017 Location: Kirkcaldy, fife Posts: 22 ![]() ![]() ![]() |
hi guys newly back into RRs ownership hoping someone can help, when I first start the car the heaters are like tepid for a minute or so then only blow cold air, have checked for air lock by opening the bleed screw, even after driving it 250 miles it was still stone cold, the cars temp stayed exactly in the centre off the dial where I would expect it to be, any ideas.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
You need to get the fault codes read. |
thanks am looking into getting the car to an independent specialist to have the codes read.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2018 ![]() ![]() |
Take it to Mike Park in Dundee. MMP is the business name |
thanks mate! wasn't sure where the best place would be closest to me |
2nd vote for mmp |
Ok so as everywhere is closed being xmas new year I soldiered away at it myself got a hold of a icarsoft lr v2.0 after checking the matrix wasn't blocked I narrowed it down to either faulty heater valve at the Fuel Burning Heater or the little water pump.
Grantgronow0705 Member Since: 30 Nov 2024 Location: Bridgend Posts: 9 ![]() ![]() ![]() |
I am getting identical issue in my 2015 RRS SVR and have changed the solenoid and water pump on the FBH just as you did. One thing I haven’t done yet is reset all fault codes which I’ll try later. If nothing still works, I’m ready to stick a hammer to the car!!! |
