![]() | Home > Maintenance & Modifications > L494 Brake pipes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
Replaced loads of them too. Little frightening that the pipes on a 4 Yr old car has worse pipes than many, much older cars on the road |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Pic please of location on the vehicle |
Best to take the wheel off if you can’t get it in the air,look in between the air bag & top suspension arm & that’s the pipe.It is bad DM,I couldn’t believe it when mine went in for service & the said my rear brake pipes were corroded,like I said before I’ve got 10-15 & even older cars coming in for MoT with brake pipes like new.
4yrs is pretty bad! They must be made of Chineseum alloy |
Hi Mate , Whats involved in fitting this pipe , my wifes offside burst last night ![]() |
Easy enough to do if your mechanically minded,pipes goes from body in front of wheel fastens to top suspension arm & down to calliper.I bought my brake pipes from Advanced factors which are site sponsors for a lot less than LR dealers. Andy.
Thanks, is it metal from the caliper then flexi and then metal again ? |
Yes metal to flexi that’s the pipe.Itscthe metal bit that fastens to the arm that corrode.
Thanks again |
IronDuke50 Member Since: 04 Jan 2021 Location: North Yorkshire Posts: 9 ![]() ![]() ![]() |
Thanks for the post, excelent.
Cover them in grease & they will last longer. Andy.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1200 ![]() ![]() ![]() |
Only the rears, or should one replace all 4 corners? --
Only the rears seem to corrode on the L494. Andy.
Do you think it's because you lot have salt on the roads in winter? --
