![]() | Home > Maintenance & Modifications > Battery trickle charger - thoughts on this please |
Thoughts on this please
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
I use a ctek, does lead acid and AGM, trickle and reconditioning. Bit more expensive but try Black Friday deals. I bought the extension lead and charge via the white tow electric plug using a connector from the site shop. Might have been the Disco3 shop. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Ad says it' has a 4 amp max charge and only suitable for engines up to 2.5l . Don't know why it would mention engine size but if you are going to be using it on a regular basis I would spend a little more and maybe get a ctek 2010 RRS, TDV8
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I use a ctek 4 amp without issue on RRS |
My car is used pretty much everyday, mostly 64 miles a day. My wife takes it sometimes and it’s only 6 miles a day. My cars to old old to have stop start, but it’s just sympathetic top up for the fleet. 2006 2.7 TDV6 HSE in Cairns Blue. |
