Home > General > Arch Liners???
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Arch Liners???
Bit of an odd one this and not a massive deal just my OCD stepping in! Whilst out in the staff car park on the phone today I was looking at my car and noticed the front wheel arch liner protruding down, then I noticed the rear doing the same and when I checked around the car saw they were all like it to a degree.
Unlike previous cars they seem to be a rubbery material, normally they are plastic and held in with little plastic 1/4 fittings or similar, pic here -
Has anyone come across this, is there a way to ‘neaten’ then up or do I just have to accept that’s how it is??
Si 2017 RR Evoque HSE Dynamic (wife’s)
2006 E86 Z4 Coupe
2017 Nissan Navara
2015 VW Amarok Black Label
2012 RRS HSE SDV6
2006 911 Carrera convertible
2016 L200 Barbarian pickup
2010 RRS Lux
2008 E93 M3
2004 VX220 Turbo Stg 2
2010 E70 X5 30d M Sport
2006 Golf R32
Post #591001 Mon Nov 25 2019 8:54pm
Quite common, need to replace the edge protectors they only push on and only generally last a couple of years or so, loads of posts on the site about them.
https://www.rrsport.co.uk/forum/topic55054.html
https://www.ebay.co.uk/itm/Genuine-Land-Ro...SwFXVZ34L6
Post #591002 Mon Nov 25 2019 9:05pm
Sit
Ok so reading one of those threads it mentions a bit of heat - if I hear mine up will they ‘snap’ back into shape?? Or do I need to purchase new ones??
2006 E86 Z4 Coupe
2017 Nissan Navara
2012 RRS HSE SDV6
2010 RRS Lux
2008 E93 M3
2006 Golf R32
Post #591008 Mon Nov 25 2019 10:33pm
The bit hanging down in your picture looks to be the wheel arch protecter rubber not the wheel arch liner it's self, heat won't achive anything you need new rubber protectors as the metal inside the protector had proably corroded away.
Post #591012 Mon Nov 25 2019 10:59pm
Brit Plumber
As Col said, the steel reinforcements within the rubber have corroded and are no longer maintaining their shape. They are scrap and the only fix is to remove or replace. Col pointed me in the direction of some Free Lander trims which are cheaper and long enough to replace the trims more than once. It looks like these LR trims all come off the same roll but the Range Rover tag increases the price. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #591021 Mon Nov 25 2019 11:34pm
ilard
https://www.lrdirect.com/CLB500051-Protector/ L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #591022 Tue Nov 26 2019 12:38am
No real point buying one's listed for the Sport will cost £70.00 for a set of four and do vehicle once. £55.00 for a set of Freelander one's and will do whole vehicle twice, and it's exactly the same item. Some people have even sold on the second set to recoup some of original cost.
Post #591024 Tue Nov 26 2019 1:05am
