![]() | Home > General > Air Suspension Etiquette?!? |
Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 211 ![]() ![]() ![]() |
Afternoon,
That’s really useful thank you, seems to be some substance to keeping it moving on a regular basis but perhaps not for the pressurised thing then. I imagine I will also use it regularly, particularly as the car in question isn’t fitted with side steps so it should make life easier day to day.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Access height is for access, off road height is for off road. Neither is a long term position - that's the standard position. I leave mine in standard height unless I specifically need to use one of the other setting (and that's more often off road height although access does get occasional use).
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5092 ![]() ![]() ![]() |
10 years of sport ownership and never bothered about leaving them in access mode or using it to any degree, and that includes leaving them for 3 months at a time while working abroad and never been a issue.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
Disconnect the exhaust pipe from the compressor and you will see how much the system gets used without you are touching one control in the cabin - it is being used all the time.
Remember that access height isn’t just for getting in and out of the car, it also saves a scratched roof in multistorey carparks with a low access barrier or ceiling......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
I park it in access because it is easier to get in and out of. Does it matter ? Nope. Do your own thing. It makes no appreciable difference to the car, to man or to beast. |
Except it wears out the compressor a lot more quickly if it is done all the time. 07MY RRS TDV6
Does it ? 100,000 plus on my car. 60k plus put in by me. No conpressor issues. If it were really such a risk why do you think the facility would be provided in the first place and/or designed such that the car can be deliberately driven with it locked in that mode ? |
Each time it is used it sucks in moist air and over time the desiccant degrades. It is not a toy and is designed to be used as needed but unnecessary use should be avoided. Change heights a few times in quick succession and see how quickly the compressor complains.
Mine just needed a new compressor at 95k miles. It was the exhaust valve that was the problem in my case. I don't overuse the height change facility but it does get changed a few times a month on average.
If parked up for a couple of weeks, then I would drive the vehicle a 2 or 3 yards when in access mode whilst parking up in order to remove any stress on the suspension bushes etc, also puts the vehicle in sleep mode. Why stress the compressor by using access mode all the time?
Yes it is and I've never had a problem using it as intended or designed for. But hey, you clearly know more than the designers so I will bow to your superior knowledge despite having had exactly no faults ever. Forums tend to report issues rather tahn non issues. I simply am giving you a contrary fact, 8 yr old car 100k miles not kms, use daily as desribed, no faults ever. Much like practically every other user. Last edited by Father Jack on Wed Nov 06 2019 9:26am. Edited 1 time in total |
[quote="garrycol"It is not a toy and is designed to be used as needed but unnecessary use should be avoided. Change heights a few times in quick succession and see how quickly the compressor complains.
