Home > In Car Electronics > Analogue TV to digital ? |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Can you get a photo of the connections you have. 2012 5.0 SC AB
Sat Oct 26 2019 10:59am |
stuartmc83 Member Since: 14 Oct 2019 Location: Scotland Posts: 7 |
Hi I can get one, I’m not sure where they are though to photograph lol. Can you help by telling me where they’re located ? |
Sat Oct 26 2019 2:01pm |
What year and model? 2012 5.0 SC AB
Sat Oct 26 2019 2:13pm |
It’s a 2005 Range Rover sport 2.7diesel |
Sat Oct 26 2019 2:14pm |
Should be in the boot on the right but if its a 2005 it may be analouge |
Sun Oct 27 2019 10:27am |
Hi it is analogue I need to find out what I need to upgrade. On the right in the boot is the DVD interchanger can’t see the TV stuff?? |
Sun Oct 27 2019 12:56pm |
If you have a factory fit unit it should be in there search this site and disco3 for pictures of where it should be if its not there you may not have the factory fit but maybe aftermarket |
Sun Oct 27 2019 3:19pm |
I’ll need to have a good look when it’s not so cold outside but I’m pretty sure it’s factory fitted |
Sun Oct 27 2019 5:39pm |
It’s in a bracket on the right side of the boot behind the radio receiver (I think). 2012 5.0 SC AB
Sun Oct 27 2019 10:17pm |
There’s only one digital unit listed, pt number 7H4219C063AB used on VIN 9A201355 on however I suspect it can be retro fitted to earlier vehicles but it may need other parts such as wiring and window amp.
Sun Oct 27 2019 10:38pm |
There's a lot on Disco 3 about upgrading also so try over there quite a few have done it |
Mon Oct 28 2019 8:17am |
