Home > Technical > Brembo Discs & Pads
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Brembo Discs & Pads
Guys.
EuroCarParts are doing a 50% off on items at the moment. Thought it would be a good time to change my pads and discs.
I dont have Brembo calipers on my 2013 RRSport. Can i still use Brembo discs and pads with the stock calipers?
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #589225 Fri Oct 25 2019 11:02am
McFarTech
This is what i am looking at
Rear pads
https://www.eurocarparts.com/p/brembo-brake-pad-10167022A
Front Pads
https://www.eurocarparts.com/p/brembo-brake-pad-10167028A
Rear Discs
https://www.eurocarparts.com/p/brembo-brake-disc-10467013A
front Discs
https://www.eurocarparts.com/p/brembo-brake-disc-10467017A ===========================================
Post #589229 Fri Oct 25 2019 11:25am
brembo sell pads/discs for common family cars etc.
You just need to be sure you are ordering the normal components rather than the uprated system
Using your reg number should help
Post #589232 Fri Oct 25 2019 1:02pm
McFarTech
Thanks mate.
Yep used my reg number on the site and that’s what it came up with in the links. I assume TRW is just the standard callipers?
Post #589234 Fri Oct 25 2019 1:21pm
knwatkins
Yes, they will fit. I have them on mine. Kev
Post #589236 Fri Oct 25 2019 2:12pm
McFarTech
Thanks mate. Appreciate the reply, ===========================================
Post #589237 Fri Oct 25 2019 2:15pm
McFarTech
Chaps.
I picked up the Brembo discs and pads. However. On looking at the front brembo pads would I not expect to see them with a cable for the wear marker? or does the range not do it in this way? Im worried I have got the wrong pads even though I put my reg number in.
The links for the pads is above in my original post.
Post #589288 Sat Oct 26 2019 6:56pm
knwatkins
You need to re-use your old one. It just clips onto the pads. Don't lose the little metal clip. Kev
Post #589289 Sat Oct 26 2019 6:57pm
knwatkins
Or if you really want to fit a new one, you can get one from ECP.
https://www.eurocarparts.com/p/pagid-wear-sensor-106670038
You just need to drop the wheel arch liner to connect. Kev
Post #589290 Sat Oct 26 2019 7:02pm
McFarTech
Ohhhhhhhh I see. Thanks mate. Was just worried I had got the wrong thing.
Changed discs and pads on my TT's and Q5's loads and first time doing the range. Still learning.
Thanks mate. ===========================================
Post #589291 Sat Oct 26 2019 7:11pm
Tyrefitter
If you have worn yours down so the warning light has come on the n you need a new wire,if not spray it with wd40 where it clips in to the pad as they sometimes snap with them being brittle plastic. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #589318 Sun Oct 27 2019 8:23am
McFarTech
Thanks mate.
No wear sensor is not worn down. Dear put new pads on the front before I picked it up. However I’m changing the discs and want fresh pads on new discs. Wear sensor should be ok. ===========================================
Post #589320 Sun Oct 27 2019 9:41am
