Home > Technical > engine number
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
engine number
I put another engine into my 2012 rrs 3.0 from a discovery how do I tell what HP it is, and were will I find the engine number Rolling Eyes
Post #588404 Thu Oct 10 2019 9:56pm
Post #588406 Thu Oct 10 2019 10:05pm
OvalAutos
The easiest way to find the engine number is by the silver tag on the N/S rocker cover (inlet manifold).
The HP of the engine is not determined by the core engine, but by the ECU mapping, injectors, exhaust configuration and a few other bits. The core engine is the same bore, stroke, crank, block, cams and heads. This applies to all GEN1 engines. GEN2 are slightly different, but the same in essence.
. Joe
Post #588422 Fri Oct 11 2019 8:20am
