Sold Land Rover Defender 110 Wolf TUM Soft Top
If you are looking for one of the coolest looking, hard as nails and most practical Defenders, this has to be it.
Not loving the New Defender looks?
One of the very latest releases from the MOD - a 1998 vintage.This is now the ultimate heavy duty all purpose soft top 110 Defender you can get. With the sides rolled up or the roof fully off this is a head turning vehicle on the road. With all of the FFR parts removed internally you have maximum usable space and less weight to carry around. Unless you are going to have a ‘show’ vehicle or pretend to be in the Army, all that gear is just getting in the way.(I have kept everything removed)
Being ex-military doesn’t mean it has to be an absolute pig to drive. The Wolf came with a 300 Tdi and PAS as standard, which means it has the most reliable and robust engine ever placed in a Defender, plenty of power and is as comfortable to drive as they get. It also has front and rear disc brakes rather than rear drums of the era. . The REMUS upgrade means it has sound deadening acoustic matting fitted too along with the chassis waxing mentioned below. Having been fully serviced with genuine parts, it drives beautifully.
This Defender also wears its battle scars with pride and has a history. Having served with 2 Royal Anglians, it’s likely to be have been based with them in Iraq and /or Afghanistan. The drivers seat box still has the sand in it that it came home with! (this is the only bit I have not cleaned, as I felt it is part of the Defender’s story)
The chassis on these are XD i.e Extra Duty and very strong, the toughest chassis ever put on a Land Rover. They are waxed with Dinitrol by the Army and this one is immaculate, no rust or corrosion at all anywhere. You won’t believe it till you see it. The bodywork has been professionally resprayed in NATO Green.
Many of the must-have Wolf features are present such as the Pioneer tool fixing kit on the bonnet and wing, the radio boxes, the radio antenna candlestick mount, quick release light guards and flag carriers. It also wears the military issue Michelin XZL tyres on the Wolf Rims (the must have steel wheel). It also has the diagonally split sliding windows with working locks and I have re-felted the channels so no rattling glass or leaks. It is also fitted with convoy lights and the latest NATO 6 way switch
Everything works and now that I have spent over £1000 having it serviced with genuine Land Rover parts at a Land Rover specialist garage, MOT'd and registered, all you have to do is tax and insure it to drive it away.
You can buy one of these from an MOD specialist that will not have been serviced or re-sprayed and it will cost you at least £20K after VAT.
Here’s the spec:
1998 Defender 110 Wolf TUM FFR Soft top 24V 2.5 300 Tdi with Power steering.
Showing 140,000KMs (approx. 86,000 miles)
Original engine (all replacement engines are painted MOD Recon Blue Green)
Remus upgrade, Acoustic matting, fully waxed chassis and body work/engine bay.
Brand new 12 months MOT
Fully UK registered with the DVLA (R918 XSW)
Full fluid drain and change on front & rear diffs, transfer box and gearbox, swivels topped up.
Local Land Rover specialist garage has done the following too:
Engine has had full oil service to include Oil, oil filter, air filter, fuel filter
Engine also had camshaft drive belt, tensioner and idler and front cover seal/gasket, front auxiliary drive belt replaced, all using genuine parts. The garage also replaced all of the rear trailing arms bushes.
5 matching Michelin XZL 7.50 x 16 tyres with good tread depths
New parts fitted:
Steering wheel
Indicator Stalk
Wiper Stalk
Hazard Switch
Pioneer Toolkit Straps
Front door seals
Door tops re-felted
NS Vent seal replaced
Vent control arms replaced both sides
Trailing arm bushes all replaced
Map light shroud
Rear number plate light
Original decals replaced
Original Military number plate re-instated.
Soft top removed and roll frame rubbed down and re-sprayed in Satin Black
Rear tub area repainted in Nato Green
All FFR ‘leftovers’ including SA80 rack removed but available if required
As a reminder, these vehicles are far stronger than the standard Defender and benefit from:
• 300 TDI 2500cc engine
• R380 5 speed gear box
• Transfer box with Hi/Lo ratio & centre diff lock
• Twill front seats
• Anti-vibration acoustic matting
• Front and rear disc brakes
• Steering Guard
• 24 volt electrics
• PAS (power assisted steering)
• Internal full roll-over protection system (FROPS)
• Heavy duty chassis and axles
• Gearbox oil cooler
• 4 x rear side facing bench seat with lap belts (all working)
• NATO tow hitch
Military Information:
MB17AA 2320998939963 NB50103101 LV2A/088DUM TRUCK UTY MED (TUM HS) 4X4 SOFT TOP LANDROVER 2.5LTR TURBO DSL (WITH EEGR) Civilian Trade Finish A0560A 2ANG 29/04/1998 SALLDBA67WA141883 25L05493B
Asking Price £12,500 OVNO.
Serious interest please PM me. Those who know me will know I don't do things by halves and this will be an excellent vehicle.
This is not the usual dog of an ex MOD Land Rover you find for low money, this is ready for civilian life and practical, ready for you to adapt.
A quick note, you may see the odd photo with a set of BFG MT tyres on - I have kept these for my hard top and put the originals back on.L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Fri Sep 27 2019 4:22pm
RRUK
I am open to sensible offers should there be an interest from anyone on the forum L319 D4 HSE
1982 Series 3 SWB
Mon Oct 07 2019 12:34pm
RRUK
Price reducedL319 D4 HSE
1982 Series 3 SWB
Fri Oct 25 2019 11:16am
RRUK
Reduced priceL319 D4 HSE
1982 Series 3 SWB
Tue Dec 03 2019 10:59am
RRUK
Cheeky bumpL319 D4 HSE
1982 Series 3 SWB
Wed Dec 11 2019 3:20pm
RRUK
Reduced price to:
Keen to Sell, need the space!L319 D4 HSE
1982 Series 3 SWB
Mon Jan 06 2020 2:48pm
RRUK
