Home > Technical > warning lights |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
You need the codes reading for an accurate diagnosis. They are all related to suspension, even the adaptive lights and DSC as the system uses suspension data. 2012 5.0 SC AB
Wed Sep 25 2019 9:44pm |
ratty2828 Member Since: 07 Nov 2018 Location: southampton Posts: 12 |
Brit Plumber
Thu Sep 26 2019 6:35am |
These warnings are quite common to a few problems, instrument cluster - can get erroneous indicator flashes and many other can bus problems, water in the glovebox fusebox is another.
Thu Sep 26 2019 10:44am |
Thanks Again Brit Plumber took car into garage mechanic says its the rear wheel speed sensor coming up as faulty
Thu Sep 26 2019 1:27pm |
Yep that will probably do it as that has an input to suspension (access to normal at 5mph, lowering suspension by ?? mm at 100mph etc), ABS is obvious, DSC is in with the suspension etc. Etc
Thu Sep 26 2019 2:33pm |
Bit Plumber,,, unit cost £140 from Land Rover Dealer plus what mechanic takes to fit so not to bad
Thu Sep 26 2019 6:41pm |
That’s a bit more than I expected but it could have been much worse. 2012 5.0 SC AB
Thu Sep 26 2019 7:20pm |
