Home > In Car Electronics > Rooftop antenna connection types
gledy2
Hi, just looking for a little info. I am retrofitting an Android headunit to a 2006 sport, and was wanting to add a dab dongle. The existing stereo has no rooftop antenna as it was without sat nav. I have bought a later model antenna, which other threads say it fits, but just wondering if anyone can clue me in to what the blue and pink fakra connections pictured are for? Hoping for a dab and fm connection!
On a side note, does anyone know if there is a gasket needed between the antenna and the roof or is the inbuilt rubber enough? It only has a blanking plate currently.
Thanks, allan
Post #587439 Tue Sep 24 2019 11:46am
Gerd1986
I thought the DAB antenna was in the passenger side boot window. I previously tried to find the Fakra connected to do the same but gave up and stuck an Arial in the passenger side boot window.
Post #587440 Tue Sep 24 2019 12:00pm
I think you will find they are Phone and GPS connectors although that could have been earlier antennas and later one's had Dab band L in the roof antenna and DAB band III in L/H rear window.. No other gasket goes with the aerial.
Post #587443 Tue Sep 24 2019 1:08pm
RobP
Blue is deffo GPS and Pink is GSM I think TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #587490 Tue Sep 24 2019 10:55pm
scarey
Post #587507 Wed Sep 25 2019 9:55am
