Home > Technical > oil leak under car
Mihai77
Switzerland 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
oil leak under car
Hi everyone,
Please see attached photo taken from front of the car (2010 RRS 3.0) with leak and suspect areas.
Any idea what it might be?
Many thanks
Mihai Gone:
2010 Bali Blue, Reverse Camera, Winter Pack, Privacy Windows, Sunroof, Steel Tread Plates.
Post #587242 Fri Sep 20 2019 10:30am
Hi. No photo showing and the ones in your gallery how the wheel arch. 2012 SDV6 - it's missing a couple of cylinders
Post #587253 Fri Sep 20 2019 3:09pm
Mihai77
OK, photo uploaded. Forgot to mention that this is shortly after timing belt and brake flexibles were changed. Called LR they said it might some residual. Will take it in ext week for check. Gone:
Post #587294 Sat Sep 21 2019 12:17pm
That looks a bit excessive to me. Even if it's not actively leaking, that they left oil hanging around after work is completed which suggests a shoddy approach. 2012 SDV6 - it's missing a couple of cylinders
Post #587300 Sat Sep 21 2019 2:33pm
Oldandconfused
And if its brake fluid, it will strip off any paint it comes into contact with.
Post #587301 Sat Sep 21 2019 3:30pm
airwolf222helicopters
Has it got ace ?
Could be that
Post #587307 Sat Sep 21 2019 8:26pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Has the level in the brake fluid reservoir dropped ?
(Or any of the other reservoirs for that matter? ie PAS, coolant, ACE if fitted, oil level)
Post #587335 Sun Sep 22 2019 5:52pm
Mihai77
The dealer confirmed that it’s engine oil and it has to do with a seal, following the timing belt change. They say the repair will be covered by the guarantee of the timing belt change. Rolling with laughter Guess the good news is that I’ll get a free oil change Gone:
Post #587638 Thu Sep 26 2019 9:21pm
knwatkins
Strange. No oil seals should be removed when changing the timing belt Confused Kev
Post #587641 Thu Sep 26 2019 9:49pm
Brit Plumber
Do they go near the oil pump tensioner? Another over torqued bolt causing a crack? This could be a lucky escape. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587642 Thu Sep 26 2019 10:05pm
knwatkins
Hmm could be. The bolt on the tensioner should only be tightened to 24nm from memory. Kev
Post #587643 Thu Sep 26 2019 10:21pm
Mihai77
In fact they never mentioned a seal just the imperviousness being affected and that they would do it for free. So obviously related to the work they did. Will ask for a clear explanation and report back Gone:
Post #587648 Fri Sep 27 2019 7:07am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Is it clear oil? could also be the transmission cooler, given the location. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #587806 Mon Sep 30 2019 4:59pm
Mihai77
Took the car back. Very unclear explanation saying it was a "joint d'ethancheité" basically an articulation which was not watertight anymore. No cost and no paperwork. Gone:
Post #588213 Mon Oct 07 2019 2:06pm
