Home > In Car Electronics > Interior Lights
Duc750
Thanks guys - still learniing this one and navigating whats function and whats fault - latest fault is the rear door won't open 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #587105 Tue Sep 17 2019 2:01pm
knwatkins
That'll be the door latch. Common problem on the RRS and the Discos. Do a search on here and on disco3.co.uk Kev
Post #587106 Tue Sep 17 2019 2:03pm
GerryG
Scotland
Re: Interior Lights
GerryG wrote:
Hi Giys
Still cant figure out this interior light issue..
The puddle lights work, as do the footwell lights, the fuse is ok, and boot light works, courtesy lights will not come on when the car door is open, but you can press the map lights on.
Ive set the lights to automatic, the middle courtesy button when pressed will turn the puddle lights off, but wont light up, im thinking the unit might be bad as I cant think of anything else,
Anyone came across this before.
Gerry
Update
The main centre unit was blown. Ordered a second hand one from ebay and it worked a treat.
Gerry
Post #597926 Mon Apr 20 2020 12:50pm
