Home > General (L494) > Bonnet open warning along with low coolant and water in fuel |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 |
Hi
Wed Sep 04 2019 7:14pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 576 |
brand new in the summer
Wed Sep 04 2019 7:21pm |
Anyone help |
Thu Sep 05 2019 9:56am |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 260 |
Bonnet switch perhaps?
Fri Sep 06 2019 2:53am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Weird electronics goings-on are often down to either battery voltage (worth checking it, even though the battery is quite new) or water ingress into an ECU connector somewhere. Any signs of water ingress in the footwells or elsewhere? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Fri Sep 06 2019 7:35am |
carpets all dry , also does not want lock off the remote but after around 15 mins you can lock the car .
Sat Sep 07 2019 6:23pm |
Driver s side headlight not working either |
Sun Sep 08 2019 5:50pm |
Topped the coolant up and changed the bonnet switch and guess what the warning lights are still on
Mon Sep 09 2019 8:38pm |
Changed tonight and is still the same |
Mon Sep 09 2019 8:45pm |
Anyone help ??? |
Wed Sep 11 2019 9:42pm |
I had assumed that you have had the codes read but re reading the posts I cant see that you have.
Wed Sep 11 2019 9:54pm |
Shippey1974 Member Since: 25 Apr 2020 Location: west Yorkshire Posts: 4 |
I have just started with this issue and after I went through a Ford so the water ingress is a real eye opener for me. but it is very intermittent |
Sat Apr 25 2020 5:39pm |
Turned out to be nearside headlight earth under the inner wing |
Sat Apr 25 2020 8:34pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
Thanks Red Arrow for letting us know the reason... it’s why this forum works!
Sat Apr 25 2020 9:00pm |
