Home > General > Buying advice
Steve144
Buying advice
Hi All,
Newbie looking for a bit of advice.....I’m looking to take my first step into RRS ownership and have been looking at the 2012MY 3.0 SDV6 with 8 speed gearbox and have a few questions...
Have been looking at 40-60k mile examples at £16,000-£18,000 but wondering if I shouldn’t be overlooking 100k mile ones at £5-6k less?? I know service and maintenance history is the important factor, i will be doing approx 25k miles a year, is there anything that a say 50k mile car is likely to need doing over the next 20-30,000 miles that maybe a 100k one has already had done (assuming it’s been looked after properly)?
Also, is a 2010/11 model with the 6 speed box worth considering? Does the 2012 model actually drive any better/have enough updates to make it worth the extra money? I’m guessing the 8 speed box may give me a bit more MPG which would be welcome doing 25,000 a year! What kind of realistic MPG should I expect, my daily commute is approx 80 mile round trip made up of 90% A road/dual carriageway and 10% stop/ start.....
Any pointers as to what to look out for at this age and mileage are most welcome. Apologies if these questions have been asked over and over again, feel free to direct me to any relevant threads!
Thanks in advance for any info.
Steve
Post #586307 Tue Sep 03 2019 8:54pm
knwatkins
Hi Steve and welcome to the forum.
Personally, if I was doing your kind of annual mileage, I would look for a lower mileage example. If you go for one with 100k+ on it, in a few years it's going to be an extremely high miler.
The best thing to do is to just get out there and start viewing to get a feel for typical condition considering the age. You will soon pick up the good from the bad. As most people on here will advise, service history and receipts to prove work has been done to schedule is key.
When you test drive, try and perform a range of turns at different speeds and also on different surfaces if possible. Front end suspension knocks are incredibly common on these vehicles and they are very good at getting through front bottom arm and front ARB bushes.
Good luck in your search Thumbs Up Kev
Post #586311 Tue Sep 03 2019 9:52pm
Oldandconfused
A 2012 car will need the cam belt and HPFP (timed) belt changing as per the 7 year interval. With a service this will be about £1,000 (maybe a bit more or a bit less depending where you go). If you find one with this documented that is a good start as it would suggest that the owner has spent money on it's maintenance. When I was looking for mine there were a lot around that were being shifted rather than get it done which isn't a huge problem if it's been well serviced, but you need to budget for it.
I bought mine from an indi who did the belts, front/rear brake pipes, rear discs, front diff breather and turbo drain mod as part of the deal before I bought it.
Post #586317 Wed Sep 04 2019 8:03am
Swagmeister
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I echo a lot of the points raised.
I am a new owner ( 2010 RRS ) and just paid £350 for the Turbo mod to be done. Its going in tomorrow for front ARB bushes and then in at the end of the month to have the rear ARB bushes done. If you can find an example where this work has been done recently thats a good benchmark along with all the other things to look for, timing kit, service history, dry carpets, smooth gear changes, and all electrics working.
Post #586335 Wed Sep 04 2019 3:26pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi Steve144
If your heart is set on a Range Rover Sport then don’t be surprised if you face expensive maintenance and repair bills that normally come with an £80k car that you now hope to buy for £16k.
If a £16k Sport we’re reliable then it wouldn’t be £16k. I suggestion you read what the writer John Ruskin wrote about paying too little.
As for 8 speed v 6 speed then definitely 8 mainly because incidents of snapped crank shafts are much rarer on vehicles with 8 speed gear boxes. And a broken crank will set you back £12-15k.
If you do decide to proceed then go in with your eyes wide open and expect the worst. If you are exceptionally lucky you might hit on a rare winner.
I’ve been pretty lucky with my MY12 owned from new but I’ve only covered 37,000 miles. I doubt I would do the RRS journey again because JLR don’t care enough about their customers. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #586339 Wed Sep 04 2019 4:46pm
LG8340
For those who can’t be arsed to look up John Ruskin’s advice here it is:
The quote attributed to Ruskin says,
“It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money — that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do.” RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #586340 Wed Sep 04 2019 4:50pm
What's in the fridge?
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
What mileage, what cost for the ARB bushes, might help the OP get an idea of running costs/ what to negotiate with?
What mpg are you V6ers getting? What mileage are you getting out of tyres?
As knw says, I looked at alot of "very good condition" cars at various dealers that were far from that. I ended up with 45k mile 58 plate 3.6TDV8 (6 speed), it's is running at 28mpg following purchase and holiday duties (i.e fully loaded) of around 600miles. It's my first RR and it certainly eats the miles in comfort, good luck Thumbs Up
Bit of research for you re real world MPG:
http://www.fuelly.com/car/land_rover/range_rover_sport 2008 TDV8 Buckingham Blue- SOLD
Post #586346 Wed Sep 04 2019 6:06pm
Steve144
Thanks everyone for the replies. Naturally I will be going in eyes wide open, I’m fully aware of the potential running costs of a car that was £70-£80k new (currently running a 2014 Jaguar XJ), just good to know the potential common issues.
I’ll be looking out for something with a good service history and receipts for work done, ideally with a lot of the common issues already addressed.
Interesting to see 28mpg from a TDV8....wasn’t expecting much more than that from a V6, maybe that V8 burble could be tempting! Very Happy
Will go out there and try a few to get a feel for things.
Thanks again for the info.
Steve
Post #586425 Thu Sep 05 2019 8:43pm
Never managed to get more than around 24mpg out of my old TDV8.
Post #586426 Thu Sep 05 2019 10:39pm
Get a TDV8. Much better than the 3.0 TDV6 - lovely low speed grunt, nice noise when asked, crank is fine, needs TLC for the turbos but is otherwise good in the engine bay. Only comes with 6 speeds in the L320 but doesn't need 8 anyway. As for fuel economy - if you want it, don't buy a RRS of any sort.
Whatever you buy, if it's done more than 50k miles, budget for a gearbox flush. Indeed, budget for one at 50k. Laggy response at low speeds is common - known issue is lack of throttle response pulling away from junctions.
Suspension bushes are consumable items. Any knocks means bushes need doing somewhere. RRS should be quiet on broken tarmac. Any heavy steering shimmer on the brakes indicates front arm bushes need changing.
Check for oil leaks underneath. Everything should be dry (of oil). Any "they all do that sir" is a warning flag. Nothing leaks unless something is wrong.
Check everything works. Check it again. Handbrake (EPB) should make a slight sigh when moving. Any screeches etc are bad. Low range swaps with a slight clunk heard with door open. Make sure it operates in to low and back to high. Ensure suspension changes height ok. It should be quick to operate and should be able to go from access to normal smoothly and quickly. Give it 30s and ask for off road height. If it goes very slowly then the compressor is tired. Check everything works again.
SatNav is clunky, DAB isn't great and suffers from poor reception. Heated seats are effective but if there is a very hot spot then a heater pad needs changing. Not difficult/expensive.
Oh, and check everything works... 2012 SDV6 - it's missing a couple of cylinders
Post #586428 Fri Sep 06 2019 12:23am
I imagine any regular urban work would knock the 28mpg I'm on overall at the moment, that and any spirited driving, but given the family on board and I stay away from cruise control we shall see. I'm on Pirelli Scorpion Zero Asim 275/40/20s which may help slightly too as one of the allegedly more fuel friendly versions of that size. 2008 TDV8 Buckingham Blue- SOLD
Post #586436 Fri Sep 06 2019 8:53am
B_Tank88
Excellent post thank you Smile
Post #592497 Sun Dec 29 2019 11:32am
