![]() | Home > General > Gearbox Torque Limits |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
Go for a quality remap by Alive Tuning, then the correct parameters will be applied within the map. There are many companies that can bung a map on a Land Rover but these guys are one of the best in the business for Land Rovers |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
From memory, it's 650Nm which is about what the TDV8 puts out. The TDV8 and Supercharged use an upgraded gearbox with an additional planetary gear, I believe, to handle the grunt. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
My re-mapped S/C has the 6HP28 rated at 650Nm and is pushing out 750Nm of torque on the Dyno. and no problems after 4 years.
drb1709 Member Since: 24 Aug 2019 Location: West Sussex Posts: 38 ![]() ![]() ![]() |
Very informative and interesting, thanks.
