Home > Technical > instrument cluster digital displays not working
rob cupples
2007 RRS TDV8. Everything is working well including the instrument speedometer, rev counter, fuel gauge and temp gauge. The digital driver information screen is sporadic, as is the mileage display. The indicator flashing dash lights stopped working today as well on the dash but all external lights work. Any ideas? New instrument panel or bigger electrical fault?
Post #585421 Fri Aug 16 2019 7:16pm
Eaters
This may be well wide of the mark, but it’s been reported here that a faulty brake light switch and/or rear brake light bulbs do throw up some strange electrical anomalies. No doubt others will be along with better suggestions but these are cheap to check/repair and worth a try if nothing better comes up. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #585422 Fri Aug 16 2019 7:20pm
rob cupples
Thanks for your reply. The brake lights are all working including the high level spoiler one.
Post #585423 Fri Aug 16 2019 7:22pm
rob cupples
apologies for doubting you Easters- I had a small fiddle with my brake light switch this morning, it seemed to produce multiple lights on the dash. I've got a genuine one ordered so hopefully this will help. Thanks for the advice!
Post #585461 Sat Aug 17 2019 10:57am
Eaters
Haha. No problem. Hope it sorts it but still no guarantees. But that’s what this forum is all about. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #585475 Sat Aug 17 2019 4:34pm
rob cupples
New brake light switch installed, new battery and negative lead. The fault remains. When I start the car first thing in the morning the dash works perfectly, then after a few mins the mileage, info display, indicator light display disappears and appears sporadically. several error messages sporadically show, check brake pads, low washer fluid etc. several audible warnings appear. it's all very sporadic! vehicle performance including suspension works perfectly. Is next step diagnostic plug in?
Post #585657 Wed Aug 21 2019 10:22am
Spangler
Had a similar issue with mine and after months at JLR they finally diagnosed a faulty instrument cluster - new one fitted and all been ok since. Worth doing the diagnostics and if it throws up numerous communication faults between various modules in the car I would be confident its the same issue on yours.
Post #585662 Wed Aug 21 2019 11:02am
rob cupples
Great- thanks for the reply. I'll likely take it to MMP in Dundee for diagnostics if I dont manage to miraculously fix it. I'm thinking instrument cluster as well.
Post #585663 Wed Aug 21 2019 11:05am
erickwan
Malaysia
One thing for sure. A faulty brake light switch WILL throw cruise control and automatic gearbox faults.
Post #585664 Wed Aug 21 2019 11:09am
rob cupples
thanks- cruise control and gearbox all working well. it's really just display faults.
Post #585665 Wed Aug 21 2019 11:12am
Eaters
Hmm. Its a shame that didn't work. Looked good for a moment.
Yeh, I think Disco Mickey in Dundee might be your best bet now. Best of luck. Robin
Gone:
MGZTT 190 2.5
Post #585673 Wed Aug 21 2019 5:56pm
rob cupples
thank you, I'll visit Disco Mike sometime
Post #585674 Wed Aug 21 2019 5:57pm
rob cupples
I've been looking into instrument cluster repair- it looks like a good value option. Has anyone experienced this?
Post #585696 Thu Aug 22 2019 10:13am
rob cupples
just had instrument cluster out, with loom connected and pressing on back of cluster the faults come and go. its likely a defective PCB in the cluster.
Post #586140 Sat Aug 31 2019 5:28pm
gogsy1956
I've looked into this in the past but never actually used the service. I came across an outfit called totaltronics based in Rugby. They seem to get a good review and you can mail your cluster to them which would be up your street seeing that you already have yours out.
I would be tempted to give them a ring and explain the problems your having,, if they can help out it would be a lot cheaper than a new unit. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #586141 Sat Aug 31 2019 5:58pm
