Home > General > suspension compressor pipes
triplemmm
Hi
Managed to get the old compressor off. I had to cut the two pipes as the collars would not push in to release.
I've cut them further up instead of near the end so I can put a straigh through connector in.
Can anyone advise/share link for suitable connectors to get to connect the pipes together?
Are these ok? 8m & 10mm
https://www.advancedfluidsolutions.co.uk/n...s-24-c.asp
I'm going to try and take the compressor apart before ordering a repair kit, in case some of the screws and bolts bust when trying to take apart. Will bite the bullet and get a new compressor if that happens.
cheers
Post #585207 Sun Aug 11 2019 6:06pm
Disco_Mikey
Britpart do a pipe repair kit Thumbs Up
Post #585208 Sun Aug 11 2019 7:15pm
gogsy1956
Look on eBay,, lots of push fit pipe connectors with the retaining collar. The type you have indicated are internal push fit for soft or flexible tubing, I doubt very much they would fit on the compressor Pipes as it is the harder pvc type.,, and no retaining device.
Search for pneumatic push fit connector 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #585209 Sun Aug 11 2019 7:44pm
triplemmm
Thanks Mikey - Do you mean this? https://www.britpart.com/parts/repair-and-...ors/da3964
Post #585213 Sun Aug 11 2019 8:55pm
triplemmm
Thanks Gogsy that makes sense. - So these?
https://www.ebay.co.uk/itm/Nylon-Air-Line-...2674688783
I then have to get bits to go into the two pipe ends as well?
Post #585214 Sun Aug 11 2019 8:59pm
Disco_Mikey
Yes, providing you have a Hitachi compressor fitted
Different kit for the AMK
Post #585216 Sun Aug 11 2019 9:40pm
triplemmm
Cheers Mikey. yep Hitachi.
The repair kit is pretty straight forward, but goodness, almost every screw is corroded. Soaking the lot in PlusGas and hoping for the best.
Would you advise replacing the relay too?
Post #585217 Sun Aug 11 2019 9:54pm
garrycol
Australia
I had to do the same on my compressor - these are just low pressure pipes - one is air intake and the other air exhaust.
I just got some short 4" long fuel pipe and use them as connectors - just fed the ends of the original cut pipes into the short fuel pipe - just make sure they are a tight fit so water cannot get in - the two original pipes are different diameters so different diameter fuel pipe in needed.
I have had this arrangement for 6 years and never been an issue - also makes it easy to remove the compressor later when it is time to do a rebuild.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #585222 Mon Aug 12 2019 4:30am
gogsy1956
No pipe inserts required for the push fit connectors,, just cut the pipes with a junior hacksaw so the pipes stay in shape 2010 RRS, TDV8
22" overfinch
Post #585259 Mon Aug 12 2019 4:54pm
triplemmm
Thanks Garry and Gogsy!
Just got to get the thing apart at the moment.
It seems that 2 fixings are seized for every one that will turn.
The screw head holding the air dryer on seems to be made out of butter. Big Cry
I'll change the filters and dessicant with it in situ.
Might have to drill 2 of the bolts holding the compressor to the frame off though.
Post #585264 Mon Aug 12 2019 7:30pm
