![]() | Home > Maintenance & Modifications > Yellow trim clips in door - Removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
you do seam to have to break them into peices to remove them!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
Don't bother, just break them off, can be removed but usually damages them and can't re-use them anyway, as they are only a few pence each to buy not worth the aggravation of trying to remove them.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Even the 'trim removing tools' don't seem to be sharp enough to get under the edges. Melting the centre with a diamond bur in a Dremel seemed to work. |
I've removed these with a pair of pincers previously. However, they did snap on the inside. Kev
That's how I started, Kev. The possibility of an eternally-rattling door made me think twice. |
they eventually make their way to the drain holes.
BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51 ![]() ![]() |
they aren't any help for them |
In the end, I melted the core with a Dremel and got the blade of a Swiss army knife under the edge. |
