![]() | Home > Faults & Fixes > Upshifting Revs Drop?! |
It may be worth doing a fluid flush on the transmission. It isn't in the service schedule but recommended by the OEM. Kev
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
I stand corrected if I'm wrong but not heard about this resetting the Gearbox by holding the accelerator down. I thought it had to be done using a suitable plug in device, normally done as part of the Gearbox flush. I had this done,, as have many others, and the Gearbox was reset so that it basically re- learns your driving style. 2010 RRS, TDV8
dxviiss Member Since: 08 Aug 2019 Location: Cambridge, UK Posts: 2 ![]() ![]() |
Thank you both for your input. Much appreciated!
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
The gearbox reset is something which was mentioned on a number of occasions on the FFRR forum!
