Home > Maintenance & Modifications > AF factors poly bushed front lower control arms. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Does anyone know how the 4 year warranty works on the AF arms? From what I understand the LR gen parts carry a 2 year warranty whereby if they fail, you take the car to a LR workshop and they will replace them FOC (providing they are happy they were fitted correctly I imagine), |
Sun Aug 04 2019 7:42pm |
Never thought about the fitting side of things. I assume if one fails in the 4 year Warranty period you are liable for removing and fitting but if (like mine) the rear bolts are seized in and you have to cut the arm out, then what? 2012 5.0 SC AB
Sun Aug 04 2019 7:59pm |
That's what I was wondering. As was suggested to me, LR would pick up the labour if theirs fails which seems very generous if they have not fitted them. Guess that, not the case with the AF ones. That being said, providing they are fitted correctly, they should be good for 4yrs. |
Mon Aug 05 2019 9:05am |
I hope I’ve fitted them correctly, apart from cutting the rear bolts out and setting the ride height (I used the real measured height rather than the figure in the manual as I’ve lowered mine by 10mm) it wasn’t to difficult. I spent more time cleaning the muck and rust off and the doing some chassis painting. 2012 5.0 SC AB
Mon Aug 05 2019 11:08am |
