Home > General > Headphones
ShooterNeil
Yes vin is very similar to yours
And the same car 61reg 5.0 sc AB 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #584880 Fri Aug 02 2019 8:31pm
ShooterNeil
Won some headphones 50£ for two
Do you pair then to the car 61 AB 5.0 supercharged rocket
Post #584881 Fri Aug 02 2019 8:32pm
Brit Plumber
No pairing necessary, they just use IR so technically any IR headphones with the same frequency would work. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584883 Fri Aug 02 2019 9:46pm
