Home > In Car Electronics > 2012 RRS DVD Issue (sound but no image)
Blade954
Hi all,
I have a 2012 RRS Supercharged with rear seat entertainment. The CD player works fine as does the TV tuner, (rear headrests work fine) however the DVD player only plays sound but no image? Any suggestions?
Post #584702 Tue Jul 30 2019 10:51pm
Brit Plumber
Is it original RSE? Does the DVD play from the head unit onto the rear screens? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584708 Wed Jul 31 2019 12:41am
Blade954
Hi, yes it is. It has a single disc head unit in the dash.
Post #584719 Wed Jul 31 2019 7:50am
Brit Plumber
Ok, is the dvd playing on the rear screens but not on the front? 2019 5.0 SC SVA (Current)
Post #584724 Wed Jul 31 2019 9:56am
Blade954
Yes and no, it plays the soundtrack and both front and rear screens show a black screen with the DVD chapter number, just no bloody video!
Post #584731 Wed Jul 31 2019 12:43pm
Brit Plumber
Can you get the codes read? It could be a loose coax between the IAM and the FCDIM or it could be your IAM is goosed. 2019 5.0 SC SVA (Current)
Post #584740 Wed Jul 31 2019 3:28pm
Blade954
I took it to my local stealer and they’ve apparently checked the physical connections. They’ve said that it may need a software update but that if the update doesn’t work properly, it could completely fry my head unit. They’ve quoted over £3000 for a new one!
Post #584754 Wed Jul 31 2019 5:50pm
Brit Plumber
Second hand units from breakers are usually between £14 and £200. How much do they want for an update? 2019 5.0 SC SVA (Current)
Post #584756 Wed Jul 31 2019 6:30pm
Blade954
£300 + VAT!
Post #584758 Wed Jul 31 2019 6:48pm
Blade954
I wouldn’t have thought that the need for a software update would cause the unit to stop playing the video on a DVD?
Post #584759 Wed Jul 31 2019 6:49pm
Brit Plumber
Agreed, more than likely they hope a software update will overwrite some corrupt data. 2019 5.0 SC SVA (Current)
Post #584763 Wed Jul 31 2019 8:37pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I previously had an issue where when watching the TV I got sound but no picture, I've no idea if the DVD worked or was the same but thought it worth mentioning that the dealer only did a software update and it sorted everything. I was quite surprised as I was expecting a hardware problem. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #584773 Wed Jul 31 2019 10:59pm
