Home > Maintenance & Modifications > Service indicator showing after just 8k miles
Jon_viola
Has anyone else had this? My car had a major 80k service carried out at RR at around 77k miles. It’s now 8k miles later and the lights back on. Should I be worried?
Post #584576 Sat Jul 27 2019 11:38pm
BKHK
Australia
Don’t know which model you have but when I had a new V8SC a couple of years ago, the service indicator countdown was quite erratic. Do a search, there are quite a few posts on the issue.
I wouldn’t be “worried” but I would get it checked in case.
Post #584577 Sun Jul 28 2019 1:50am
garrycol
Australia
I work in metrics and my service interval is 12000km which is 7500miles so it is telling you your next service is due - seems all correct to me. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #584578 Sun Jul 28 2019 2:48am
Brit Plumber
What model as later cars have a known issue with oil dilution and is a contributory factor towards damaged/snapped cranks. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #584591 Sun Jul 28 2019 1:16pm
BKHK
Australia
garry
I think that here in Oz we have services every 6 months , double that of the Poms? I certainly used to have 6 month intervals on my 2.7 all those years ago.
Post #584597 Sun Jul 28 2019 5:06pm
garrycol
Australia
Mine is 6 months/12,000km - no idea if it is different elsewhere.
Irrespective the service indicator uses a simple countdown method, and is irrespctive of what is happening in the engine and vehicle.
In the case of the OP, if when the vehicle was last serviced the indicator was set to come on after 8000m then that is when it comes on. With my resetter I have about 10 different options for time and distance. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #584612 Mon Jul 29 2019 2:33am
riverblanche
Hi,
you dont mention how Long ago it was Question
if its 12 months then its due on time even if not miles (model depending?)
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #584643 Mon Jul 29 2019 6:52pm
Mrterence
Hi guys need advice, I have seen an 05 RRS 4.2sc for sale the guy seems pretty genuine and has informed me that the vehicle has not had an oil service in 4yrs of ownership in which he's covered 29000m the current milage is 120000m with full history up to 91000m, but the car sounds and drives ok, I'm going to check the oil on the next viewing, should I walk away now?
Post #587208 Thu Sep 19 2019 5:11pm
Brit Plumber
You could argue that it’s done 2 1/2 x the time on the oil it should have done however some would say that cars are overserviced these days. Some modern military vehicles get oil changes on condition which is a great idea so a sample is tested every set period and the results decide on the action and when. The vehicle could have done 20,000 miles at 60mph with little load and always at the optimum temp but it as easily could have been stop/start fully laden at 0 to 100 and back to 0 every day. You just don’t know. It’s a gamble, it needs the price of a very good major service knocking off at the least. And if it’s not been serviced I would check every item works and isn’t broken as the chances are it won’t have been fixed properly, if at all. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #587252 Fri Sep 20 2019 2:57pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Buy from someone who cares, not that kind if ignorant.. Censored
Post #587276 Fri Sep 20 2019 9:09pm
knwatkins
I agree with the above. Walk away and buy a car from someone who has looked after their car. Kev
Post #587277 Fri Sep 20 2019 9:24pm
ilard
No, don’t walk away, Mrterence! Shocked
Run. Run like Censored
But appreciate the seller’s honesty. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #587280 Fri Sep 20 2019 10:02pm
Mrterence
The thing is it’s cheap at £4250 has no advisories on the mot history and he messaged me last night to say engine warning light came on which came up as fuel correction fault bank 1 and 2 malfunction, the garage thinks it’s an air leak in the system or dirty fuel as it is not used on a regular basis. Now with it being a Land Rover I know there are going to be problems so I’ve got my head round the fact it may be a money pit but my main concern is the engine and would the lack of an oil service be catastrophic or would an oil flush and oil and filter change sort it, ideally I am wanting some sound advice from an owners past experience or horror stories with regard to lack of oil servicing.
Post #587297 Sat Sep 21 2019 1:47pm
knwatkins
Bearing rotation can be an issue on the TDV6. Old and dirty oil will contribute to increased wear on all moving mechanical components.
If it were me, I'd spend a bit more and get a well looked after example. But ultimately, it's your choice. You may be lucky. Kev
Post #587298 Sat Sep 21 2019 2:11pm
